bigger injectors
Old Aug 16, 2005 | 07:36 PM
allstock's Avatar
Default bigger injectors
i was wonderin if the stock DSM 440 injectors would work in my b16a. I can get them for dirt cheap compared to new injectors.
Old Aug 16, 2005 | 10:46 PM
sacicons's Avatar
Default RE: bigger injectors
yeah, but it will run rich as hell, and your mileage will go to crap. and i may be wrong, but i think they need a little modifying to fit. not sure how much though.
Old Aug 17, 2005 | 12:26 AM
Street Sniper's Avatar
I think you just need to Dremel the seals out a little bit.
Check it out: DSM injector install.
But, like Sac said, unless you are boosted I don't think you need 440's.
Old Aug 17, 2005 | 12:30 AM
sacicons's Avatar
hell, even light boost it would run rich. 310s would be more than enough for most street turbo setups.
Old Aug 17, 2005 | 10:30 PM
allstock's Avatar
im about to turbo the car and i plan on running 9 to 11 psi.....so wat would be the best injector size since the stock dsm are too big
Old Aug 17, 2005 | 10:57 PM
You can run the 440's if you tune for them. You could run a garden hose in there if you tune for it, but you can't just drop 440's on a stock ECU. If you can get the DSMs for dirt cheap then use some of the money you save to get a really good tune.
Old Aug 17, 2005 | 11:47 PM
sacicons's Avatar
get the dsm 310s instead.
Old Aug 18, 2005 | 12:02 PM
AgentofDarkness's Avatar
What if u get an adjustable FPR and dial the pressure down?
Old Aug 19, 2005 | 10:44 PM
sacicons's Avatar
that will help, but a professional tune would be the only way to get them right.
FastCat
Feb 13, 2008 05:31 PM
redridinhood
Oct 4, 2006 10:11 PM
Fiasco
Aug 3, 2006 12:17 PM
Big T
Nov 14, 2005 09:44 AM
fast93civic
Dec 28, 2004 11:17 PM
