Bigger injectors or regulator?
with cams, headwork, or FI. but you could use one now, but to remove fuel. if you drop the pressure by 1 or 2 psi at a time, you can pick up an hp or two. the factory tunes cars "safe' from the factory, read:rich. if you lean it out just a little, you can get a little gain, but dont go too much, or youll get detonation. and high octane would be a good idea if you lean out your fuel.
Hey got a quick question, since the D17 is a returnless fuel system would I be able to use an aftermarket FPR? I know Comptech makes a universal one, but not sure if thats only universal for returned fuel systems.
FastCat
Feb 13, 2008 05:31 PM
Fiasco
Aug 3, 2006 12:17 PM
