Block Resurfacing
Well.....
I need to get my block resurfaced because it is all scratched up and not shiny and might be warped.
So i have to go down to a bare block, engine is pulled.
What should I do? If i pull out my pistons do i need to get new rings or what not? i dont know anything about pistons or cranks or anything. the guy said bare block does that include the oil pump and all that stuff?
Riceburner! fill me in!
It might be better to ask the guy who's going to mill your block about how he expects it
If you were going to pull pistons out and replace the rings, I believe you're supposed to rehone the cylinders. You may choose to bore it first (requiring oversize pistons). The piston rings aren't easy to get to and if I have enough miles on the engine (I guess I'd say...150k+ miles), I would do it. What I know about installing them is that (after honing), you have to set the 3 piston rings in so that the gap in each one is offset by a 120 degree rotation (1/3 of a circle over each time), then use a piston ring compressor to squeeze them while you put the piston back in the cylinder.
I don't know if there's more to it than that. Feel free to rip me a new one, riceburner
if the cylinder walls are fine and the engine didnt burn any oil just pull out the pistons and rods and remember which cylinder hole they went into. yes the block needs to be stripped as far down as it can go, dont want metal shavings in your oil pan floating around. Just tell them to take off the bare bones minimum. Dont forget a new head gasket and head studs unless you got some ARP's in that baby
ORIGINAL: riceburner700
And i do have arps in that baby
Well...
number 1 my dad went to the block with a file in his attempt to straitin it out. has some pretty deep gouges in it.
number 2. we checked it with a strait edge and its low in the middle
Number 3. The head has been resurfaced, and head gaskets are still failing. Points to the block
