Cam Gears
what is the point...i dont think it will do you any good unless you have aftermarket cams or a chipped ECU...you would be doing nothing without aftermarket cams
someone can correct me if im wrong.
i think its when i told him to calm his ***** in his other post.
https://www.hondacivicforum.com/m_567547/tm.htm
ORIGINAL: rudedawwg
i am looking to put some on my stock 99 si but my main question is, do you guys think its worth it?? and do i really have to upgrade my cams in order to get the most out of the gears
Bro, the point of adjustable gears is to make timing/tuning easier, they wont give you any increase in power. Your gears won't mean anything until you put some better cams on it.
ORIGINAL: Exhausted
So nobody else caught the "Do i have to upgrade my cams in order to get the most out of the gears?"
ORIGINAL: Hailchristian
