Change my 01 civic non Vtec to Vtec
I'm looking to change my Non Vtec to a Vtec. I have the Apexi Neo Air Fuel & VTEC Controller all i need is a new Vtechead and headgaskets am i correct?
RE: Change my 01 civic non Vtec to Vtec
Thank You Lost, that post was very informative. I was also wondering if it would just be easyer to put in and D17A2 in the place of my A1 non vtec. ( If anyone has done this head job on a D17 let me know how it went )
List of Parts: Needed for a D17A2Vtec Head Swap Required: D17A2 Cylinder Head (Including distributor cap, valve cover, plugs/wires, VTEC solenoid, etc) D17A2 Head Gasket Apexi Neo Air Fuel & VTEC Controller D17A2 Timing Belt Wire and plug for VTEC oil pressure switch Optional: D17A2 Intake Manifold D17A2 Exhaust Manifold *If you remove your manifolds, make sure you get new gaskets* Recommended: NEW OEM- Water Pump Spark Plugs Spark Plug Wires Valve Cover Gasket Distributor cap and rotor |
forget the D17 and lookinto a D16Z6.
Thanx for the advice Lost but i want to build a D17"No offense to anyone with an D16Z6"
| All times are GMT -8. The time now is 10:35 PM. |
