Crankshaft Broke! Honda Reliable!
Old May 15, 2006 | 06:39 PM
opivyspike's Avatar
Default Crankshaft Broke! Honda Reliable!
This happened like a year ago, and I never posted it.
But I was driving from austin,Tx to Dallas,Tx , its about a 3 hour trip!
I was driving about 90 or so for about an hour, then I had to get gas. And to this point Ive noticed nothing wrong,but as soon as I push in the clutch, it starts shaking like crazy(clutch pedal).
So I turned the down music from blasting, and It sounded like a piston was going up and down hitting the head! too me. Im not that well with engines!
So I turned it off looked under, nothing had busted under the hood, nothing was leaking. Now Keep in mind I had no cell, and in middle of nowhere. So I tryed to start It back up,and it did, I had to jam it in gear, literally slam it..clutch pedal was going crazy, the motor sounded ****dd..but that 97 Honda CIVIc DX made it another 2 hours of driving at 80, all the way home to the driveway..with a tourqued off crankshaft inside!
Old May 15, 2006 | 06:48 PM
ef4life's Avatar
Default RE: Crankshaft Broke! Honda Reliable!
how did the crank break
Old May 15, 2006 | 07:10 PM
opivyspike's Avatar
Somewhere between the 1st hour.I have no idea how.
When I got home I parked it and then took it too the shop and the crank was is in two pieces.
Old May 15, 2006 | 07:11 PM
riceburner700's Avatar
just goes to show you how hondas are really tough and can still run even with a broken in half crankshaft.... did you snag any pics?
Old May 15, 2006 | 07:16 PM
ef4life's Avatar
its hard to belive, but anything is possible. i ran my del sol on the pistons with a hole in the block, and #2 in my hand
Old May 15, 2006 | 07:36 PM
MY99SI's Avatar
did you notice if the idiot (oil pressure light) on at all? if so did it start knockin at all?
Old May 16, 2006 | 01:24 PM
Nail I3unny's Avatar
man thats some crazy ****. im pretty sure the CFT Civic is running a stock crank...and its putting over 750hp to the ground...
Old May 18, 2006 | 12:05 AM
thedougler's Avatar
that is insane...
rydnlow1120
12
Feb 5, 2008 05:53 AM
tinman1412
Oct 29, 2006 04:37 AM
RedlineZero
Jul 27, 2006 04:42 AM
tallford78
Apr 16, 2006 12:22 PM
garosenb
Mar 11, 2006 01:16 PM
