d series swap?
Old Feb 18, 2006 | 02:06 PM
speedstream's Avatar
Default d series swap?
i have an 89 civic hatch dx w/ a d15b2 engine i want a swap for d16y8 so i can have vtec and not a big price tag i want to kno if theres a website that sells used d-series engines? i also want to kno if i would be needing a new tranny? i kno most of u will say that i should get a zc but if i break something on a zc the parts are hard to find
Old Feb 18, 2006 | 02:10 PM
mxs's Avatar
mxs
Default RE: d series swap?
Check out this thread: https://www.hondacivicforum.com/m_165164/tm.htm
Old Feb 19, 2006 | 04:10 AM
jwsimons's Avatar
harder than canging the engine will be the ecu... obd0 to obd2
Old Feb 19, 2006 | 12:28 PM
isnt it a complete replacement or do i have to modify the wiring? i thought i would just have to pull the old engine and ecu a/c unit etc and install the new engine ecu a/c unit etc.
Old Feb 19, 2006 | 12:42 PM
Nail I3unny's Avatar
you need to re-wire and you might have to drill a hole in your firewall. IMO it would be easier to swap in a z6.
Old Feb 19, 2006 | 04:01 PM
wats the difference?
Old Feb 19, 2006 | 06:30 PM
Kappa22's Avatar
Don't bother with a 5G engine in a 4G. Just put in a SOHC ZC (yes, it has VTEC). Your life will be much easier, and you'll end up with more power than a Z6 or a Y8. And no, the parts are not that hard to find. Any ZC site will give you a list of all the Honda part numbers.
Old Feb 19, 2006 | 07:40 PM
jwsimons's Avatar
agreed
ORIGINAL: Kappa22
99silverSI
Apr 6, 2008 01:49 PM
topdogmancivic92
Aug 28, 2006 09:12 PM
S240161
Nov 3, 2005 08:35 PM
00exinfl
EK Swaps
Mar 28, 2005 10:29 PM
