d15b
Old May 16, 2006 | 01:31 AM
Marty's Avatar
Default RE: d15b
ORIGINAL: lorenzoOKC
so then I can use d16 rods
yes
Old May 16, 2006 | 10:44 AM
lorenzoOKC's Avatar
Default RE: d15b
Nail I3unny why do you say it is a d15b7 cause mine is the non-vtec and if you look at pics of the non-vtec they say 16 valves on it to
Old May 16, 2006 | 01:05 PM
ef4life's Avatar
Default RE: d15b
a d15b is a vtec engine and only from japan. a d15b2 is a no vtec from 88-91 a d15b7 is a non vtec from 91-95
it is possible to use d16 rods in all these engines, you just need custom pistons that are shorter from the piston pin to the top, because the rods are longer and regular pistons for a d15 or d16 will collide with the head.
a jdm d15b uses d16 rods and the special pistons only available to that engine.
Old May 16, 2006 | 03:24 PM
Nail I3unny's Avatar
Default RE: d15b
i say its a b7 because i know what engines are in what cars. a non vtec d15b in a USDM EG...its either a b7 or a b5 and statistics of which cars are on the road tell me its a b7....what trim is it?
Old May 17, 2006 | 02:10 AM
lorenzoOKC's Avatar
Default RE: d15b
if it was a b7 or a b5 would it say it on the block or would it say d15b also
Old May 17, 2006 | 02:20 AM
lorenzoOKC's Avatar
Default RE: d15b
or are you saying it prob. has a d15b7 head on it
Old May 17, 2006 | 09:31 PM
Default RE: d15b
no all d15bs just say d15b on it...because theyre all the same block with different heads. marty correct me if im wrong...but all the JDM D15B Vtec engine is is a d15b block with a z6 head on it and a slightly more agressive cam.
Old May 23, 2006 | 01:08 AM
lorenzoOKC's Avatar
Default RE: d15b
ok maybe I don't have a jdm d15b but can i swap a d16 crankshaft in the d15
Old Jun 19, 2006 | 12:51 AM
Marty's Avatar
Default RE: d15b
ORIGINAL: Nail I3unny
No you are not correct.
The JDM D15B is like a de-stroked D16Z6. It has the stronger rods of the d16 but has a shorter deck than even a usdm d15b2 or b7. The JDM D15B is like a basturd child of the D series family with it's only short fall being a shorter deck but the only reason it is a shortfall is when you try to buy aftermarket pistons for it.
Booger
EK Swaps
Aug 9, 2011 10:11 PM
frewcivic
Jun 7, 2005 10:06 AM
jaidedeye
Apr 21, 2005 01:12 PM
Zenkis15
Mar 16, 2005 09:03 AM
TrixCiviC
Feb 28, 2005 11:49 PM
