d15b7 buildup
i have a 93 civic lx with a d15b7/5 speed tranny. What i want to do is swap head to 1.6 vtec and rebuild entire motor with new cam and run boost and maybe sum nos. right now i have the turbo kit and engine rebuild kit. So my question is what head do i need to get for swap, forged or regular pistons, and what kind of cam should i put in.
RE: d15b7 buildup
Someone said it on here before; It'g going to be hard to run boost and nitrous together. Maybe if you get a good tune, I'm not sure.
RE: d15b7 buildup
some a1 pistons will put you at a sweet 12:1 compression ratio.
RE: d15b7 buildup
ORIGINAL: Nail I3unny some a1 pistons will put you at a sweet 12:1 compression ratio. For just the a turbo set up OEM cast pistons/rods will get you to about 200-250whp safely. Above that you'll need forged both. I'm not a fan of nitrous so I wouldn't know what to tell you about that. For the head, the D16Z6 is easiest to use and it works well. For the cam maybe contact Akmee. |
RE: d15b7 buildup
if i get a z6 head what will need to be done the ecu, and can i run 8 pounds of boost on stock pistons.
RE: d15b7 buildup
idk about on a d15 but on a d16y8 you can run 7-8 psi safely no more than that though. and i have never seen it but someone was talking about spraying the nitrous straight into the turbo idk if you can do that or not though. if you boost i wouldnt spray
RE: d15b7 buildup
aren't b7 rods whimpy?
RE: d15b7 buildup
Yeah....I was told by many on here, that b7 rods can maybe handle 5lbs. The other option is to have them shotpeened.
RE: d15b7 buildup
ORIGINAL: Kedawei ORIGINAL: Nail I3unny some a1 pistons will put you at a sweet 12:1 compression ratio. |
RE: d15b7 buildup
could it be vitaras?
| All times are GMT -8. The time now is 05:59 AM. |
