Db15B2 swaps? new guy here...
Old Mar 16, 2005 | 12:22 PM
StealthFox's Avatar
Default Db15B2 swaps? new guy here...
just picked up a cheap 91 civic hatchback, standard model, with the 1.5 liter....good for the gas mileage now, but i've been searching around for the list of motors which are clean fits in this model car, with no major welding, or mounts in different places...or maybe turbo applications for my stock motor? from what I found the B16A motor is a straight swap, but what vehicles came with this motor?? what I am really looking for are some good websites with step by step info and PICTURES hehe, i like pictures, I am pretty familiar with engines in general, but not hondas...thanks guys
Old Mar 16, 2005 | 08:39 PM
finalimpact's Avatar
Default RE: Db15B2 swaps? new guy here...
all single cam 88-00 motors will fit in your car with minor modifications to sensors. if you intend to stay single cam there are 2 things you need to do other than getting another motor(if you want another one)
1-mpfi conversion
2-si transmission
mpfi conversion will net you better throttle response, better gas milage(so ive noticed), and slightly more power. the std tranny is not nearly as bad as the crx hf but shares the same 1-4 gear set with the dx 3.8 final drive. any dohc vtec engine requires some minor fabrication to your frame workings along with some re-wiring. the b18a/b requires the same frame mods with less wiring dependant on the year motor.
Old Mar 17, 2005 | 09:52 AM
hondabboy's Avatar
or you can drop an h22 [sm=badbadbad.gif] but thats alot of work lol. i suggest you go for the ls(or ls v-tec),b20 or the b16 cause those are good motor for the civic.
Old Mar 20, 2005 | 06:47 PM
Kappa22's Avatar
Actually, 4G's don't require frame mods for B series swaps... the only additional things you NEED are axles, shift linkage, and motor mounts.
EDIT: Meant to say 5G's.
Old Mar 20, 2005 | 09:49 PM
^^ 4g requires a hammer to make room for the alternator with a b series swap. also the front transmission mount(on frame) needs to either be beaten flat or cut off as it will not clear your transmission(dependant on mount kit)
Old Mar 21, 2005 | 02:52 PM
Kappa22's Avatar
Never had a problem clearing the alternator...
Old Mar 22, 2005 | 12:43 PM
ORIGINAL: Kappa22
use a shorter alt belt? every swap ive done had clearance issues with the alt.
Old Mar 22, 2005 | 01:24 PM
Kappa22's Avatar
Were they in 4G's? I'm just curious...
Old Mar 22, 2005 | 01:57 PM
ORIGINAL: Kappa22
yeah, all 88-91 civic/crx ive done required it. never had to do it in 92+ chassis
Old Mar 23, 2005 | 02:46 PM
Kappa22's Avatar
Oh crap, my bad!!! I ****ed up big time. In my first post, I said 4G's don't require frame mods, but I meant to say 5G's. You're right about 4G's. I just noticed that when I asked you about whether you had done them in 4G's, since I didn't have any problems when I did 5G swaps. SORRY...
