In dire need of help (engine problem)
Old Apr 12, 2006 | 07:03 AM
Vexorg's Avatar
Default In dire need of help (engine problem)
Im not sure if this was a bad idea, but i put my car on ramps yesterday and i left it there over night. The front two wheels of my 2001 honda civic coupe ex are lifted about 8 inches off the ground. Now i cant start my car up and for some reason the wireless lock/unlock functions dont work from my key (so i have to use the keys to open the door). When i use my key to try and turn the car on nothing happens. I think it might be that my car was filled with half a tank when i put it on the ramps (so the gas has trained to the back of the tank). I need some help quick before my mom comes home and learns ive messed up my new car -_-
Old Apr 12, 2006 | 07:11 AM
99civic_boosted's Avatar
Default RE: In dire need of help (engine problem)
Dead battery
Old Apr 12, 2006 | 07:13 AM
Vexorg's Avatar
why did it die because i left my car up like that ? i have a 30 day warranty for the car ( since its used ) , or i can just jump start it right?
Old Apr 12, 2006 | 07:24 AM
My thought to the dead battery is probably far fetched but if you have a light under your hood and it works off of a mercury switch, it is possible that the light was on all night long.
Check and see if you radio, head lights and dome light works if not try jumping it.
Old Apr 12, 2006 | 07:27 AM
Vexorg's Avatar
i cant even start the car up
Old Apr 12, 2006 | 07:48 AM
StifflersMom's Avatar
Cat Fuсker
you lights should work no matter what you do...if they're dead, than it's a battery
Old Apr 12, 2006 | 08:00 AM
Street Sniper's Avatar
Take it off of the ramps and see if the problem persists.
Old Apr 12, 2006 | 08:22 AM
Vexorg's Avatar
ORIGINAL: Street Sniper
i cant, the car wont let me change gears!
Old Apr 12, 2006 | 08:23 AM
Hmm, well... jack up the back even with the front.
Old Apr 12, 2006 | 08:50 AM
Vexorg's Avatar
ok im going to try and jack up the front but i want to see if anyone can give me definite answers on these questions
could it be that the engine cant get any gas, so nothing works?
what would explain the car not changing gears?
since the keyless entry thing isnt working doesnt that mean the battery is dead for sure?
