distributor
Old Jan 30, 2008 | 08:04 PM
javon's Avatar
Default distributor
my car start when it wants to sometimes. it will not crank i just bought it. i changed the o ring on the distributor because it was leaking oil bad at the bottom of the distributor and on the transmission but it is still leaking. could the distributor be the reason why my car don't start all the time?
Old Jan 31, 2008 | 01:50 PM
javon's Avatar
Default RE: distributor
anybody i need help bad
Old Feb 1, 2008 | 05:52 AM
You need three things for a motor to start/run.
Compression
Fuel
Spark
Are you getting spark to the wires? Is your motor getting fuel? Run a compression test to make sure things are kosher in that department.
Old Feb 1, 2008 | 02:42 PM
jamned's Avatar
I'd run the diagnostics like forty said, but only if it's cranking and not starting. You said it's not cranking, so I just want to clarify: Is it cranking at all? If not, then your starter or wiring is problematic.
baker7598
Jun 21, 2005 11:47 PM
indawaitinroom
Jan 27, 2005 07:21 PM
ohbiskits
Dec 6, 2004 09:32 PM
mcbob
Nov 22, 2004 03:24 PM
