Does The ZC Vtec = D16Z6?
My Engine is starting to give with all the recent head problems and me driving it about 600 miles a week having problmes starting it ive been to the local engine places where they sell jap engines and when i asked for the d16z6 they told me the zc was it in (jdm) im new to the import scene so i dont know anything they showed me the engine it was a ZC and had the Vtec valve cover and all that i want to know is this the same engine and putting in all my components will it pass smog
RE: Does The ZC Vtec = D16Z6?
It's not the same, but it'll work. Some of the brackets are different, and off the top of my head, I think it either has one more or one less sensor. Also, being from Japan, it packs a bit more punch. And yes, it will pass smog.
which brackets wouldnt work if you remember
Well, if I recall, the jdm power steering bracket doesn't fit the USDM pump or something like that (and I think the A/C bracket too, if you have it). All the bracket bolt holes on the block are the same, so you just have to switch them. The best thing to do is just swap all your original brackets onto the ZC. That will make sure everything works.
ty i appreciate your responce
ok a few more questions which do you think would be the better swap the Zc or the original what i have now im really considering the zc and if i go with it would i have to swap my distributor in there? also is the water pump and timing belt the same as the D16Z6?
Basically all i wanna know is are the ZC parts the same as the D16z6 such as water pump timing belt spark plugs
Here's the part numbers and/or what they come off of.
Alternator Belt 31110-PM5-305 88-91 CRX Si A/C Belt 38920-PM5-A04 88-91 CRX Si RT Engine Mount 50805-SH3-040 88-91 CRX Si LT Engine Mount 50821-SH3-040 88-91 CRX Si Frt Engine Mount 50840-SH3-000 88-91 CRX Si RR Engine Mount 50810-SH3-040 88-91 CRX Si Thermostat 19300-PM3-003 88-91 CRX Si Thermostat Gasket 19308-PJ7-000 88-91 CRX Si Water Pump 19200-P01-004 88-91 CRX Si Oil Pan Gasket 11251-P01-004 88-91 CRX Si Lower Radiator Hose 19502-PM3-000 Crank Seal 91212-PE0-662 1989 Integra RR Main Seal 91214-PH1-013 1989 Integra Cam Seals 91203-PG6-013 1989 Integra H/C Cover Gasket 12341-PM7-000 1989 Integra Dist Cap 30102-PM7-016 1989 Integra Dist Rotor 30103-PM5-A05 1989 Integra Ex Manifold Gasket 18110-PG6-003 1989 Integra Intake Gasket 17105-PG6-s00 1989 Integra Head Gasket 12251-PM7-003 1989 Integra Timing Belt 1988 Prelude 2.0 |
are you thinking of the DOCH ZC?
F**k. Sorry about that. I wasn't thinking. I've only done DOHC ZC swaps in my 4Gs, so that's what I'm used to working with. I'll try to find the SOHC list. I think some are the same though.
