Engine Choosing
Go street race yourself into a wall.
EDIT: Figured i'd help you.
Check out the D15Z1, it's only got 90hp but because of VTEC-E it makes you have 180hp when you pass 3k RPM.
,_________________________
|......Ownage.........................| ||_
|...........By NikeH34d..............|| * \___
|_..._..._______________---_--||_|_|__.]
/(O)(O)_____________ /(O)(O)*****(O)____________________________________ _____________
lol you would know how to make a truck like that ha
not just any b18 yo. B18c obd2 typ r. pushes 200+ just cuz u have a stock block u cant put turbo and run good boost u need to upgrade engine crank, rod, pheads, value, spring, cams, clutch- then u get performance if u run boost stock its not worth uall ruin the block itself n there good penny r motors 3500 n up n LSD trans way to go
