Engine Oil Level???
Old Aug 10, 2008 | 02:15 PM
yuchi's Avatar
Default Engine Oil Level???
I just got a new civic, when I check the engine oil level, it's not even have any oil on the marker, I added a bottle of 5W30, but still... just a bit black mark on the tip of the marker. anything wrong with this marker or i need to add more oil to it??? :
Old Aug 10, 2008 | 02:50 PM
Did you make sure you're checking the level when the engine's cold? Is this a new car, like 2008? Or did you just mean it's new to you. There are 2 holes in the oil dipstick. The oil level should be above the lower hole on the dipstick.
Old Aug 10, 2008 | 03:20 PM
yuchi's Avatar
it's 2000 civic se, and i checked the level in the moring when it's cool. I'm sure about the dipstick. but there is no mark on the dipstick after add a regular bottle of engine oil.
Old Aug 10, 2008 | 03:27 PM
i'd just give it an oil change just to be safe. whenever i get a used car the first thing i do is give it an oil change.
Old Aug 10, 2008 | 03:42 PM
yuchi's Avatar
Default yuchi
thx for the advise
Old Aug 10, 2008 | 04:28 PM
Having found the oil level so low, begin checking it frequently to figure out whether the engine has a significant oil leak or is burning a lot of oil.
Old Aug 10, 2008 | 04:57 PM
Originally Posted by ronj
having found the oil level so low, begin checking it frequently to figure out whether the engine has a significant oil leak or is burning a lot of oil.
ron = beast
Old Aug 10, 2008 | 05:19 PM
dito... first off get a oil change, then check it every few days..
if theres no oil on the dip stick than that oil is VERY LOW!!!!!! best to drain the oil and refill it with the right amount of oil and a new filter as well.
northwoods
Feb 3, 2013 09:17 PM
oilltd
Jun 10, 2008 04:06 PM
StifflersMom
Nov 28, 2004 05:51 PM
nicolas
Aug 19, 2004 11:47 AM
