engine problem
ok guys, i have a 92 civic and when i drive it for about a half an hour it will sort of cutt out. What i mean is ill be driveing down the road and ill punch the gas lightly and the engine acts like it is stalling, then i let off the gas and a few seconds after the engine will come back strong. Any ideas what it could be?
thanks |
RE: engine problem
check the fuel system.........replace the fuel filter and fuel presure regulator......id also make sure the spark plugs are not dirty........and make sure they are gapped correctly.
RE: engine problem
yeah my dad 89 civic hatch had a similar problem. the mechanics said it had to do with the fuel injection and regulator
RE: engine problem
i just bought a fuel filter and a fuel pressure regulator. I also bought a cap and rotor because my dad had an f-150 that did the same thing and it was the cap and rotor
RE: engine problem
check spark plugs
RE: engine problem
ok guys, i replaced the fuel filter, the cap and rotor and the fuel pressure regulator. I checked the plugs, they look new so i gaped them and put them back in. The "sputturing" is not as close to as bad as it was, but if i just sit there in neutral and hold the gas at around maybe 1000-1500rpms the engine will sputter down and go back to its idle. One of my friends said it could be the fuel rail. I looked at some on ebay and i was wondering if i could use them on the stock fuel system.
http://cgi.ebay.com/ebaymotors/ws/eB...category=33553 i think that will work im not sure though.....thanks |
