engine ques.
Old May 8, 2007 | 08:52 PM
Mycull's Avatar
Default engine ques.
aight so i get most my questions from my friend... so correct me if im wrong!
now i got a 01 EX, with 101,000 miles and want an engine swap in the future...
His engine just blew because of some stupid oil problems, and he wanted a B16, but he says that they are no illegal... so i want to know all this stuff bout engines...
Are all your cars registered, and if so how?
Old May 9, 2007 | 09:01 AM
StifflersMom's Avatar
Cat Fuсker
Default RE: engine ques.
it's basically illegal to swap in an engine older that the car. So your two options would be either a D17 or a K-series swap.
Old May 9, 2007 | 09:07 AM
danomatic93's Avatar
June 2010 ROTM
^+1 ditto, reason being that newer cars have more strict regulations and emission rules. Older cars don't have the same regs and rules so the engines don't comply with the newer regs and rules. It sucks, but it's true.
Old May 9, 2007 | 09:17 AM
couldn't he get a b16 from a 99-00 SI though? They're both (the si and his ex) obd-II, aren't they?
Old May 9, 2007 | 10:17 AM
Cat Fuсker
can't do it. It's 2001 and that si engine is from 99-00
Old May 9, 2007 | 10:19 AM
FlipHKD720's Avatar
how much money you got? K series swaps are expensive, but from what i hear the horsepower is well worth the time/effort/money.
Old May 9, 2007 | 10:20 AM
Fiasco's Avatar
quite the condundrum. Your only choice is that k beast. Theyre expensive as hell.
Old May 9, 2007 | 10:37 AM
FlipHKD720's Avatar
your friend has a D17A2 in his 01 EX, thats127 hp @ 6300 rpm & 114 ft·lbf @ 4400 rpm. The only D's you could swap in would be an A1, A6 or A7, in which case you would be losing power on all (and VTEC on some). A K20A2 would put you at 212 bhp @ 8000rpm and 149ft·lbf @ 7000rpm with an 8400 redline. You've got the best of the 01+ D series, so you could replace the D witha nother A2 and build it up, or swap the K.
Old May 9, 2007 | 11:09 AM
ScoobyAddict14's Avatar
formerly aryiman98civic
i had no clue that you couldnt swap in an engine from an older car. i learn something new everyday. but could someone explain that if you dont have to do emissions in your state, can you still do it?
Old May 9, 2007 | 12:42 PM
Remmy's Avatar
ORIGINAL: aryiman98civic
Nothing but a little time and effort and money wouldnt hurt.
But ultimatly a k would make more sense
