Engine Rebuild! Please Reply!
Old May 23, 2006 | 10:51 PM
HelpMyHonda's Avatar
Default Engine Rebuild! Please Reply!
Okay, What is involved with an Engine Rebuild? i am thinking bout Re-building my D15b2 Stock Honda Engine in my 88 Civic DX. But i'm not sure in what it requires. it has 277,xxx km's on it so i think it's about time. Any Info you can give on this subject would be much appreciated.
Old May 24, 2006 | 08:03 PM
Kappa22's Avatar
Default RE: Engine Rebuild! Please Reply!
It's a fairly easy rebuild compared to a lot of other things. You don't even have to pull the engine. Here are the basic steps:
1) Pull the head
2) Take off the oil pan
3) Pull the crank girdle
4) Take off the con-rod caps
5) Drop the crank
6) Pull the pistons.
It's VERY important that you mark each con-rod with something so that each piston goes back in the same cylinder it came out of, since you probably won't be getting the cylinders honed.
Hope that gives you a basic idea.
Old May 24, 2006 | 10:19 PM
94DXProject's Avatar
What gets replaced in an engine rebuild?
Old May 25, 2006 | 04:11 PM
Kappa22's Avatar
Whatever you want. I usually do rings, main bearings, head gasket, cam & crank seals, and oil pan gasket on anything, other parts as needed.
Old May 25, 2006 | 04:17 PM
AgentofDarkness's Avatar
How are you going to get the pistons back in with the ridge on the top of the cylinders? I would take the enginge out of the car and do a proper rebuild. It takes more time but the outcome will be better. You can have the engine block acid dipped to make sure its cleaned and have it machined. I would replace pistons, rods, main and rod bearings, piston rings, and all the seals/gaskets.
Old Jun 1, 2006 | 03:56 PM
Kappa22's Avatar
ORIGINAL: AgentofDarkness
What I posted IS a proper rebuild if you know what you're doing. You can do everything you need to do in a Civic rebuild without pulling the engine, ESPECIALLY on an EF.
The way you get the pistons back in is you use a ring collar to hold the rings in, then align them with the cylinders and tap them in with a rubber mallet. Internals 101.
Old Jun 11, 2006 | 01:43 PM
x2100's Avatar
What is the cost of such a rebuild?
For example on a 2000 ex engine
Old Jun 11, 2006 | 02:05 PM
Pete's Avatar
More than its worth lol. You could get a newer JDM D15 motor with around 35,000 miles for like 800 bucks.
Old Jun 11, 2006 | 08:00 PM
ORIGINAL: Kappa22
I think i confused my self there, i know about the ring collar and i've used it before but never on an engine with a ridge on it.
addiction2bass
Jan 27, 2007 06:27 PM
89si
ED-EF Swaps
Apr 24, 2006 02:28 PM
smokingemcee
ED-EF Swaps
13
Jan 9, 2006 11:26 PM
civicmotorhead
Dec 5, 2005 06:55 PM
