Engine reving`
MMMMk, well, I'm not to brilliant when it comes to engine stuff.. so sorry if i sound retarded... anywho.. my car sounds like an f1 car when It's idleing at around 1k rpm, it spikes up to 1.5, back down, up, down... evnetually when it warms up past 1k rpm it will stop, and it wont do it above 1.2k rpms ish, I dont know how to fix it, but i've been told its a cheap part you can buy from wal mart..... they didnt know what it was called..
I'm thinking maybe 02 sensor possibly.. but... I dont know, any suggestions? |
RE: Engine reving`
its probably your iacv is dirty on the firewall side of your intake manifold just take the two bolts off and clean the screen off with some carb cleaner or brake clean and should take care of your problem
RE: Engine reving`
or even easier - check you coolant level, could be a lack of coolant...
RE: Engine reving`
spark plugs/plug wires too. Mine was idling really bad and that was what was wrong
RE: Engine reving`
ORIGINAL: FlipHKD720 spark plugs/plug wires too. Mine was idling really bad and that was what was wrong |
RE: Engine reving`
i would have to go with misha and riceburner on this, cause thats what its allways been on hondas when they do that. never seen the wires cause that
