Engine reving`
Old Jan 28, 2007 | 10:49 PM
CheatyMcShiftyEye's Avatar
Default Engine reving`
MMMMk, well, I'm not to brilliant when it comes to engine stuff.. so sorry if i sound retarded... anywho.. my car sounds like an f1 car when It's idleing at around 1k rpm, it spikes up to 1.5, back down, up, down... evnetually when it warms up past 1k rpm it will stop, and it wont do it above 1.2k rpms ish, I dont know how to fix it, but i've been told its a cheap part you can buy from wal mart..... they didnt know what it was called..
I'm thinking maybe 02 sensor possibly.. but... I dont know, any suggestions?
Old Jan 28, 2007 | 11:16 PM
riceburner700's Avatar
Default RE: Engine reving`
its probably your iacv is dirty on the firewall side of your intake manifold just take the two bolts off and clean the screen off with some carb cleaner or brake clean and should take care of your problem
Old Jan 28, 2007 | 11:59 PM
Misha's Avatar
or even easier - check you coolant level, could be a lack of coolant...
Old Jan 29, 2007 | 01:35 PM
FlipHKD720's Avatar
spark plugs/plug wires too. Mine was idling really bad and that was what was wrong
Old Jan 29, 2007 | 02:32 PM
Misha's Avatar
ORIGINAL: FlipHKD720
I really doubt it has anything to do with wires. Fast idle valve, either dirty or with air buble, fits the description perfectly.
Old Jan 29, 2007 | 11:31 PM
civicblend97's Avatar
i would have to go with misha and riceburner on this, cause thats what its allways been on hondas when they do that. never seen the wires cause that
Williamdon
Mar 3, 2011 02:49 PM
icecoldstar
May 30, 2008 11:05 AM
H22
Nov 20, 2006 05:46 PM
RoundEyeRacing1904
17
Aug 3, 2006 11:40 PM
Zer0Ale
Jul 20, 2006 12:48 AM
