Engine Swap
Hi,
I am new to this forum and was wondering if any one can offer advice as to engine swaps. I have a 1990 civic with a 1.6 CC engine. I was wondering what other engines could be easily swapped in to improve performance etc. or should I just rebuild this one. It has over 200K on it and is starting to show its age.
Thanks
Thanks
actually there is 3 versions of the zc......sohc non vtec, dohc non vtec, sohc vtec(jdm z6). personally if you want to stay sohc id stick with your a6 block(im asuming yourr car is an si) being is still has the steel main caps as opposed to the one peice alum mains found in 92-00 bottom ends. how much money do you have to spend? there are other options such as the integra ls engine, b16, gsr, etc......
