Engine Swap
Old Jun 11, 2007 | 05:57 PM
Bigwill93hb's Avatar
Default RE: Engine Swap
actualy it would be about 2400 with shipping! and osme of them i seen say that the engines are from japan and other say its a junk yard
Old Jun 11, 2007 | 08:25 PM
b_rice burner's Avatar
ya my choice would be the b18 it is by far my favorite to watch go in a perform... 2400 is a good price just like they said double check on the source... so ya id def think about the b18 for any time it is alos a good travel engine too.
Old Jun 12, 2007 | 09:19 AM
johnny's Avatar
I'll say the B18
Old Jun 12, 2007 | 12:43 PM
ic892003's Avatar
ORIGINAL: jc6711
h22 with b-series tranny.
since when can u interchange different series trannies?
and ill go with b18
Old Jun 12, 2007 | 01:52 PM
MY99SI's Avatar
theres a kit out now that is basically an adapter plate that you bolt to the engine and trans that allowes you to use the b series trans with an h series motor.
the H2B conversion
Old Jun 12, 2007 | 03:01 PM
riceburner700's Avatar
its a mighty fint kit^^^ also comes with a flywheel spacer
Old Jun 12, 2007 | 05:01 PM
ic892003's Avatar
i didnt even know that, whats the difference, faster ratio times??, how about the strain on the tranny?? would it be hard considerign its going from a lessp owerful engine to a h22?
Old Jun 12, 2007 | 05:34 PM
now i found out this kid i met did a b16a1 swap in his CRX ? and its a good engine! so now im not sure again! are all b series motors the same when it comes to swaping them like the amount of work and fitting setup ect....?? and with the b18c anyone know how the stcoktrannys are that they come with?
Old Jun 12, 2007 | 05:40 PM
MY99SI's Avatar
ORIGINAL: Bigwill93hb
you've got to make sure you've got the right mounts for each side of the engine (drivers side, pass side, rear mount)
everyengine is a little different. not all of them are identical.
what do you want to know about the b18c trans?
Old Jun 13, 2007 | 03:30 AM
i wanted to know if they were good trannys if there were any bad things about them, are they good for a lill racing?
