engine wont start
Old May 12, 2009 | 04:05 PM
2fastcivic94's Avatar
Angry engine wont start
Engine will turn over but wont start. please help..........
Old May 12, 2009 | 05:45 PM
when you turn the key, before turning and holding to start the engine, does the check engine light come on and can you hear a buzzing-ish sound (fuel pump priming)?
Old May 12, 2009 | 05:56 PM
Also check for spark at the plugs (see Spark link in my signature).
Old May 12, 2009 | 06:44 PM
i have a hi flow fuel pump on it so i can hear it kick on. and yes there is spark to the number plug. I have no suction through my intake? even when i open up the throttle.
Old May 12, 2009 | 06:46 PM
try starting it with the gas pedal pushed down a little. If the intake has no suction when you are trying to start it without the gas pedal pushed down, I would think that would point to a clogged IACV.
Old May 12, 2009 | 06:47 PM
done that as well bro and still nothing.
Old May 12, 2009 | 06:50 PM
you mean eacv?
Old May 12, 2009 | 06:51 PM
Check whether the timing belt slipped a few teeth.
Old May 12, 2009 | 06:52 PM
i just reset the timing tdc
Old May 12, 2009 | 06:54 PM
tensioned belt properly too?
