factory mounts???
well, as you know, my ZC died on me, so i'm upgrading pretty soon. i have 3 choices in mind. b16a1 or a2, and b18b1. just wondering if the factory mounts for these would work in my 95 ex coupe.. or would i have to mix-and-match.
i might be wrong but im pretty sure the mounts are the same. im not sure if all the B16 mounts are the same? because i know the A2 and A3 will both drop right in to a 5th gen civic without changing the mounts.
nice, i think i'll go with the a2. i know its a lot of questions, but would i have to upgrade the ecu, or is the p28 suitable enough, and what about wire harnesses?? i hear the a2 is just a "drop and arrange" for the ej1, but i could be wrong.
i could be mistaken, but according to http://www.clubcivic.com/board/showthread.php?t=47678 , the stock ZC ecu should be suitable for the a2.
the engine(auto) come with all this:
- Complete Block
- Intake Manifold
- Complete Head
- Engine Wiring Harness
- Sensors
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Throttle Body
- Alternator
- Starter
- Ignition Wires
- A/C Compressor
- Power Steering Pump
- Intermediate Shaft
- Factory Mounts
is there anything vital that is missing from the list. the general problem i read from other forums is about shift linkage and axles. and please, comments only, i posted this question in other forums, and all they do is tell me how easy it all is.
- Complete Block
- Intake Manifold
- Complete Head
- Sensors
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Throttle Body
- Alternator
- Starter
- Ignition Wires
- A/C Compressor
- Factory Mounts
fastest_ex
May 8, 2005 03:33 PM
