fuel injectors
Old Aug 15, 2005 | 07:56 PM
importcivicus's Avatar
Default fuel injectors
What are the size of a 99 civic ex Fuel injectors?
Old Aug 15, 2005 | 08:08 PM
sacicons's Avatar
Default RE: fuel injectors
240cc
Old Aug 16, 2005 | 08:43 PM
what is the best size to run n/a and what style? (saturated and peak hold)
Old Aug 16, 2005 | 09:27 PM
Street Sniper's Avatar
240cc injectors running at a recommended maximum of 80% duty cycle can support 38 Hp each. Multiply that by 4 and you get a 152Hp max for your stock injectors. The thing is though, you will need to either adjust fuel pressure or the injector pulses to accomodate the need for added fuel.
Saturated are a little more durable but peak and hold will deliver your fuel a few milliseconds faster. I would suggest sticking with the style that you have in your car now.
Old Aug 17, 2005 | 09:40 PM
what style is in the car is what we are trying to figure out?
Old Aug 17, 2005 | 09:42 PM
Saturated (high impedence), 240's
Old Aug 18, 2005 | 09:08 PM
will 310's be tomuch for n/a engine?
Old Aug 19, 2005 | 10:37 PM
sacicons's Avatar
probably. unless you have a pretty radical build, 240s will be fine.
Old Aug 23, 2005 | 08:29 PM
is there an upgrade 240 injectors, and where can I find them?
Old Aug 27, 2005 | 12:47 PM
Blackhatch124's Avatar
what about stock b16's...what size are the injectors in those?
