Glowing cat
Old Jan 19, 2006 | 08:37 PM
bw1339's Avatar
Default Glowing cat
Hello,
I finally finished retiming my 91 Civic DX (1.5L 16V) and as I had the engine idling in my driveway, I noticed that the cat was glowing red. I'm assuming that this is a sign that the engine is running rich. I don't get any check engine lights or anything abnormal. The engine stumbles a bit taking off, but seems to run fine. What could be causing this?
Thanks,
Mikel
Old Jan 19, 2006 | 08:50 PM
XCM828's Avatar
Default RE: Glowing cat
Actually it might mean you are running lean because things start to get a lot hotter when you are running lean.
Old Jan 19, 2006 | 08:58 PM
AgentofDarkness's Avatar
Maybe the cat is clogged and the excessive exhaust pressure is causing it to glow red. There was a car where i suspected that the cat was clogged, the exhaust manifolds glowed red after a couple of min of idling.
Old Jan 19, 2006 | 09:31 PM
Nail I3unny's Avatar
how long does it take for the cat to start glowing?
Old Jan 19, 2006 | 09:45 PM
riceburner700's Avatar
If the cat is glowing then it is ruined, something probably broke inside and it is clogging the flow through the exhaust system.
Old Jan 19, 2006 | 10:53 PM
neon3kgt's Avatar
^^^ what he said is usually the cause.
Old Jan 20, 2006 | 12:05 AM
99civic_boosted's Avatar
Agree - clogged
Old Jan 20, 2006 | 12:56 AM
Pete's Avatar
get out the drill, hollow that bitch out.
Old Jan 20, 2006 | 08:21 AM
bw1339's Avatar
Thank you all
Old Jan 20, 2006 | 08:36 AM
If you hollow the cat out then it won't work. Then you fail emissions.
