ground wires
I have heard you can get like 5 hp and 5 tourqe if you replace the stock grounds with fatter ones and add some more. I know you run them from the negative on ur battery. From your battery where do they go? How many grounds should i run? I have a d16z6. hit me back playas!
RE: ground wires
doesnt the kit come with a diagram? if not, i guess you would have to do it trial and error to find which lengths fit to which stock grounding locations. if youre building your own kit, then just look for the stock grounds and replace them with new wires. but you shouldnt just jam more wires into the terminal, you should use some type of distribution block, so that all the wires are nice and tidy.
RE: ground wires
yea just make sure u do it correct the FIRST time and remember u GET WHAT U PAY FOR
