head swap
i have a d16y8 can i put a obd2 vtec gsr head on my motor. or is a head swap even worth it?
RE: head swap
it can be done. but it will envolve enormous amounts of machine work. i've seen it done once before with a d16y8 with an LS head on it. the guy who did it was a machinst and did it all himself. it envolves relocating the coolant passenges in the head and stuff like that.
so unless you've got money to burn i'de suggest not |
RE: head swap
with as much as your gonna spend to get a gsr head on a SOHC cam block you could buy a gsr motor and install it into your car lets put it that way lol. Good rule is you can only interchange D-series to D-series, Bseries to Bseries, hseries to hseries etc.
