HELP NEEDED, IM NOT A RICER! IM A POINT A TO POINT B TYPE GUY
Old Feb 19, 2007 | 06:31 PM
StifflersMom's Avatar
Cat Fuсker
Default RE: HELP NEEDED, IM NOT A RICER! IM A POINT A TO POINT B TYPE GUY
well jsut the items listed above as your tune up....honestly I would replace all the vacuum hoses come spring....DIY job if you pick-up some silicone hose:-D
knfdeals's Avatar
what is seafoam??
Old Feb 19, 2007 | 06:33 PM
knfdeals's Avatar
yeah earlier me and my mechanic friend back when i first got the car changed the spark plugs, and the brakes by ourselves....the labor isnt really a prob for me.. im just going to buy all the parts online at once and do everything ASAP so I can keep this great machine running!
Old Feb 19, 2007 | 06:34 PM
Cat Fuсker
make sure you SOAK the wingnut on the alternator adjuster REALLY WELL in penetrating oil like PB blaser or WD40. or it WILL break:-D
Old Feb 19, 2007 | 06:40 PM
knfdeals's Avatar
thank you, i probably would have broke it if you didnt help me with that
Old Feb 19, 2007 | 06:43 PM
knfdeals's Avatar
so an IACV idle air control valve controls the rpms idling? controls the amount of air coming in???
Old Feb 19, 2007 | 06:44 PM
Cat Fuсker
and don't try to heat it up either. The rod is aluminum and will burn through if you try to heat the nut. You can tell that I broke one once:-D
Old Feb 19, 2007 | 06:45 PM
knfdeals's Avatar
oh yeah my friend has said my CV boot was leaking... im going to buy that too now as well... what exactly does that mean??
Cat Fuсker
ORIGINAL: knfdeals
yes. it sometimes can be removed and cleaned out. A new one is around $130. At your milage I would look into vacuum leaks FIRST and than at the IACV.
Old Feb 19, 2007 | 06:46 PM
Cat Fuсker
ORIGINAL: knfdeals
That means you're buying a new axle. Don't just replace the CV boot as you don't know how much junk already got in there and what damage has been done. Lifetime warranty axles are like $90-130 at advance or zutozone.
