HELP PLEASE
Old Oct 29, 2006 | 07:54 PM
  #21
Misha's Avatar
Default RE: HELP PLEASE
Sucks man.Good luck
Old Oct 29, 2006 | 11:19 PM
  #22
Kedawei's Avatar
Here's a general guide to compression.
Engine—What is a healthy engine???
Compression test results should be as follows:
* 8:1-8.5:1 compression: 150-170 psi per cylinder
* 8.5:1~9.5:1 compression: 170-210 psi per cylinder
* 9.5:1~11:1 compression: 210-275 psi per cylinder
* 11:1+ compression: 250+ per cylinder (highly depends on cams being used)
Your rings aren't sealed yet I presume. Break them in and see what you come up with.
Old Oct 30, 2006 | 07:46 AM
  #23
StifflersMom's Avatar
Cat Fuсker
that compression test looks like cam timing to me actually. Reason being I don't think rings would provide for such a uniform comp test. I would run a leakdoiwn test and THAT will tell you right away where you have a problem.
Old Apr 23, 2007 | 08:12 PM
  #24
BIMMERGUY's Avatar
So what was the problem? What fixed it?
Old Apr 25, 2007 | 11:02 AM
  #25
the_turtle's Avatar
if its JDM, then the firing order is oppisite of USDM right? my friend had that problem with his talon.
which could lead to being 180* off time...becuase 180* is oppisite..or half of 360.
Old Apr 25, 2007 | 11:42 AM
  #26
Misha's Avatar
As far as I remember,my JDM one was the same...
Old Apr 25, 2007 | 11:53 AM
  #27
FlipHKD720's Avatar
Misha ^ still creepin around (sorry i cant help T34)
DontHateOnEG8
20
Sep 6, 2008 06:49 AM
dhdicato
Apr 14, 2008 07:25 PM
D16racerchick
Jan 3, 2008 05:15 PM
redridinhood
Oct 9, 2006 07:27 PM
Honda99Civic
Apr 20, 2006 10:13 PM
