How to get 2000 SI in the 12s?
Old May 24, 2008 | 11:48 AM
Max713's Avatar
Default How to get 2000 SI in the 12s?
Hi, Im trying to find out what it will take to get a 2000 Civic SI into the mid 12s... Im thinking turbo but there are so many kits out there I have no idea where to go... Id like to keep it under 3K for a turbo setup(used is fine)... what other supporting mods would I need with a turbo? How much boost can I run safely on a stock motor? Can I get into the 12s with just a turbo?
Old May 24, 2008 | 12:16 PM
jpnolan's Avatar
Default RE: How to get 2000 SI in the 12s?
ok turbo is a good plan but its not something you jump into asking questions like how much boost shows you need to reseach a TON check stickys on the turbo section. 3k is a lot for a turbo im hoping mine will total around 1.2k. all i can tell you is RESEARCH!!! sooooo much because amount of boost depends on what turbo, what tune, and what injectors.
my05civic
Apr 14, 2007 07:24 PM
Tater
Jan 29, 2007 07:58 PM
mikeryan161
Jan 24, 2007 07:24 PM
bmxedup
Jan 18, 2007 08:26 PM
Fejery4491
Aug 4, 2006 06:27 PM
