how many quarts of oil
Old May 30, 2007 | 07:01 PM
ic892003's Avatar
Default how many quarts of oil
i purchased 4 quarts of royal purple motor oil 5w-30, how much of it do i actually have to use hwn i change my oil, i have a 92 civic with d15b7 motor, it is 1.5l sohc 16 valve not a vtec
Old May 30, 2007 | 07:41 PM
civicexracer's Avatar
Default RE: how many quarts of oil
3.5qts. to be 100%sure, check ur owners manual.
Old May 31, 2007 | 04:41 AM
ic892003's Avatar
I don't have my owners manual, I bought the car used and I don't think it came with 1
Old Jun 3, 2007 | 07:46 AM
theredsuit's Avatar
3.8litres with a new filter is what it says. It also should be writen on the airbox. Another good way is to pour in 3 litres then add small amounts and check the dip stick between adds. Get the oil to the top mark adn start your engine to fill the oil filter. Give the car a couple revs and shut it down. Wait 30 seconds then check your dipstick. Add small amounts of oil until the level touches the top marker. You're done and you have the correct amount of fluid in your car.
oilltd
Jun 10, 2008 04:06 PM
AntiRiceYO
Oct 21, 2007 03:26 PM
stonerdan
Apr 15, 2006 06:28 PM
triggerstep
Jan 27, 2005 10:52 PM
