i need new wires and plugs
hey i am new to this so bare with me if i ask something stupid. I am not a car genious but i am a fast learner and pretty sharp. i only have cool air intake and skunk2 suspension done to my car with of course aftermarket body work. So as you can see much more to be done. I am all for good looks but i want to put most of my money under the hood. Firts question is what is a good place to start for making more power. I am aware that headers and exhaust are a good start but i don't have the money right now. So can anyone tell me if i was to start with the electrical what are some good things. I was thinking to beef up the wires first and plugs. are the phat wires good? Or is wires not something i should do untill i have the iginition beefed up? Any advice would be helpful
thnx mirosh |
RE: i need new wires and plugs
i would have to say iginition would do you more good than wires and plugs, unless yours are totally ****ed up. from what i remember ignition systems are quite expensive.
An ignition system is not going to be worth the cost on a stock engine. Unless your running so many mods that your engine is constantly misfiring, you will not benefit from an upgraded igntion. You can get plugs and wires, but again this will not give you that much power. If you need plugs and wires anyway then upgrading to something better isn't a bad idea. How much money do you have to spend?
nology makes really good thick/fat wires that look good and perform really well to
ORIGINAL: AgentofDarkness An ignition system is not going to be worth the cost on a stock engine. Unless your running so many mods that your engine is constantly misfiring, you will not benefit from an upgraded igntion. You can get plugs and wires, but again this will not give you that much power. If you need plugs and wires anyway then upgrading to something better isn't a bad idea. How much money do you have to spend? |
but MILL, dont u have to "tune up" the eng. first then header and exhaust? btw which header and ex are GOOD and cheap? how about eBay shiet?
no^^^ you just slap the header and exhaust on the car tighten everything down and you are good to drive it were ever you want to go
