I spent $450 replacing water pump & timing belt? why??
Old May 25, 2007 | 04:35 PM
ELLAS1945's Avatar
Default I spent $450 replacing water pump & timing belt? why??
Firstly, I just got this auto civic 1996 lx and just realized that it dirt cheap to actually replace the motor with a newone. So then, y do we bother replacing the water pump and timing belt when we can just buy a new enginez for a little more? Noob question!
Secondly, having spent and replaced timing belt and water pump, Im thinking I should just Mini-me my DI6y7, for a bit of performance enhancement
Or
should I save and buy a b series motor?
will and b-series engine fit my 1996 civic lx ?
Old May 25, 2007 | 06:45 PM
jeff948594's Avatar
Default RE: I spent $450 replacing water pump & timing belt? why??
the motor you put in isnt usualy brand new, its probably already about half the way to needing the new waterpump and belt plus it is a little easier to change a water pump than it is to swap an engine.
Old May 25, 2007 | 06:50 PM
Fiirkan's Avatar
Replacing the waterpump and timing belt is called preventative maintenance, so you wont be driving down the road and have it crap out on you
Old May 25, 2007 | 07:28 PM
t34me's Avatar
you can do it yourself to save money, but after your first time doing it, you will see why dealership charges you so much in labor.. Honestly, after a couple times, aint no thing.
Old May 25, 2007 | 08:04 PM
Pete's Avatar
If u wait too long to do the T belt, it could snap on u. Snapping T belt means Bent Valves. A new head is much more than a new T belt...........you can say no to the new T belt and water pump, but when the top of ur motor blows up, youll be sorry.
LIhybrid
Oct 13, 2005 03:04 PM
smokingemcee
Aug 9, 2005 10:36 PM
jjgarcia
Aug 22, 2004 07:39 PM
