Leaking water pump
Old May 12, 2008 | 02:17 PM
sboarder97km's Avatar
Default Leaking water pump
I juust got my car back from the shop today and they said my water pump is leaking antifreeze, but its gonna be about $500 to fix it. Its not leaking too much and my engine isnt over heating but it is hot. I dont really have $500 now and dont really wanna spend it on it so im justn wondering how important it is to fix it right away and also how easy it would be to change myself.
Old May 12, 2008 | 02:33 PM
JakeyMan07's Avatar
Default RE: Leaking water pump
well you need to change a water pump if it is leaking it is prolly just the seal on the water pump mine was like that and it just got worse and 500 dollars is crazy to fix a water pump buy one for about 80 or i think i paid 65 for mine and than fixed it myself thats what i would do have a buddy help you or something they are real not hard to change
Old May 12, 2008 | 03:18 PM
The most difficult part of the job is re-installing the (new) timing belt EXACTLY as you removed it. Study the service manual carefully prior to starting the job and consult the forum often when you have questions. Also, don't break off any of those water pump bolts - they require very little torque.
http://hondatech.info/downloads/Auto/Manuals/Civic/
http://www.civicforums.com/forums/7-...t-96-00-a.html
Old May 12, 2008 | 03:41 PM
Well I have a haynes book for 5th gen civics but the engine was swapped so now it has an 89' acura integra engine in it so I may have to find an acura one online. And is it for someone whos pretty new to cars, or most likely too difficult?
Old May 12, 2008 | 03:59 PM
It will be a challenging job for someone without much experience; however, by doing your homework and having/obtaining the necessary tools, the challenge can be overcome.
Old May 12, 2008 | 04:39 PM
I know that because my engine is DOHC it means doing the timing belt is alot more complicated and would have to rent the tool from like Autozone or something like that.
Old May 12, 2008 | 06:22 PM
JakeyMan07's Avatar
o yah dont forget to put your timing belt in the exact same spot i was replacing one one time and i told my buddy to not take that belt off and i came back and he did and well he thought he had it in the right spot well when he went to start would not start for anything and bent i cant remeber how many rods he ****ed that thing up but yah do your homeowkr on it first
flcb7
Nov 3, 2010 05:21 PM
lbiasotto
Oct 20, 2007 06:59 AM
cnote
Apr 16, 2006 04:31 PM
mill$civic
Dec 13, 2005 05:36 PM
