loud squeel
If it's a stock drive pulley you probably just need to tighten or replace the belt. If a pulley has been replaced, check that the pulleys are aligned quite closely in the same plane side to side or there will be noise. If necessary replace the pulley or shift the alternator.
noupf
Dec 1, 2008 12:22 PM
