Massive Hesitation
Old Aug 12, 2005 | 09:14 PM
AnakinKenobe's Avatar
Default Massive Hesitation
Ok so i have pretty much fuixed my car and all of the things it failed for inspection, so i start it up and there are no coded or check engine light on, and it starts fine its just when i go to give it some gas i put my foot down and it goes grrrrrrrrrrrr vrooom, and after a little bit i can have the pedal floors and it wont go past like 500 rpm, timing is on and my plugs are gapped correctly, new fuel filter too, any one have any ideas, im gonna recheck the timing tomorrow, i think it needs some tuning ...
Old Aug 13, 2005 | 12:03 AM
XCM828's Avatar
Default RE: Massive Hesitation
Do a compression test on all 4 cylinders. Also, make sure there are no vacuum leaks on the intake mani. It could also be something wrong with your tranny.
Old Aug 13, 2005 | 01:42 AM
sacicons's Avatar
timing belt been off lately?
Old Aug 13, 2005 | 02:33 AM
compressions fine, no vacuum leaks at all, tranny is good, timing belt was off but ive had the timing gun on it3 or 4 times already and its perfect... someone told me it may be a bad tps or air idle control sensor..
Old Sep 2, 2005 | 01:32 PM
chriskatana's Avatar
ORIGINAL: AnakinKenobe
I'm havig the same problem.
Did you find a resolution?
________
Utg Airsoft 1911 Pistol Silver
DaRKoN
Aug 19, 2007 05:05 PM
cnote
Mid West
Jun 14, 2006 01:06 PM
amg6975
Jan 13, 2006 03:37 PM
barryscivic
Aug 22, 2005 09:15 PM
