Motor Mounts?
Old Mar 20, 2006 | 01:30 PM
05HonVic's Avatar
Default Motor Mounts?
What is the exact purpose of putting aftermarket motor mounts on your engine? When you are not swapping the engine, it is still the same engine that came in the car but you just replace to mounts. Just wondering what this does
Old Mar 20, 2006 | 01:38 PM
Marty's Avatar
Default RE: Motor Mounts?
It stops wheel hop on launchs and lets the engine move less giving it quicker response
Old Mar 20, 2006 | 01:39 PM
05HonVic's Avatar
Ok cool thanks alot. You dont happen to know if they make mounts for a 2005 LX d17 do you? i did a few searches but was not really too successful. Any help on that search would be well appreciated.
Old Mar 20, 2006 | 03:05 PM
Marty's Avatar
You can also buy mount inserts, I'd say hasport has something along with energy suspensions
Old Mar 22, 2006 | 12:46 PM
rit14623's Avatar
This probably sounds silly, but I think I get wheel hop from driving a stock D15B7 when I floor it.
How difficult it is to install Energy Suspension motor mount parts? I've never really looked at the motor mounts. Is it as simple as bolting and unbolting nuts?
Old Mar 22, 2006 | 01:24 PM
Marty's Avatar
No some mount inserts you have to have pressed in with a hydrolic press but if you are changing the whole mount than IMO it is easy.
Old Mar 22, 2006 | 01:28 PM
So Marty, do the stock ones slide out, or are they likely to end up being little bitches like the ones I'm pulling out of my LCA's right now?
Basically, is it going to be hard to get the stockers out?
Old Mar 22, 2006 | 07:51 PM
importcivicus's Avatar
IMO it would be easier to replace the whole mount instead of just replacing the guts. They are pain in the a** to replace. you need to do one side at a time. leave them lose when you install them to get them all in. Then tighten when all installed.
Old Mar 22, 2006 | 09:08 PM
AgentofDarkness's Avatar
I don't think that its worth it to get performance motor mounts. They cost like $400 and won't give you too much better times on your 1/4 mile. If you've done everything else, then the motor mounts are a good way to get the last tenths of a second out.
Old Mar 23, 2006 | 09:28 AM
Shot I got mine for $310 from password JDM The have types of mounts. I got the 85A mounts the motor dont move at all.
