Motor Mounts?
Old Mar 23, 2006 | 09:51 AM
rit14623's Avatar
Default RE: Motor Mounts?
I don't understand what it is that Energy Suspension motor mount bushings are. It sounds like, from their description, that you leave the stock rubber bushings in place and clamp on the polyurethane pieces over them, but I don't know how things all looks.
Any use Energy Suspension or Prothane motor mount bushings and have pics?
Old Mar 23, 2006 | 11:32 AM
ORIGINAL: AgentofDarkness
I don't think that its worth it to get performance motor mounts. They cost like $400 and won't give you too much better times on your 1/4 mile. If you've done everything else, then the motor mounts are a good way to get the last tenths of a second out.
bah, I disagree. Last time I took my Civic to the track, granted I was rocking stock steelies and stock tires, but I wheel hopped half way down the damn track. I'd LOVE to illiminate my wheel hop
Old Mar 23, 2006 | 03:43 PM
importcivicus's Avatar
with new mounts (polyurthane) and with a new wheel set up and better suspension I have now wheel hop at all.
Old Mar 23, 2006 | 04:00 PM
AgentofDarkness's Avatar
poly bushings are alot harder than the regular stuff so they don't move or flex. This keeps whatever you are putting the bushing on (mounts, sway bar, etc) a lot stiffer.
Old Mar 23, 2006 | 04:07 PM
they take forever to install to. But yeah AOD
Old Mar 23, 2006 | 11:33 PM
riceburner700's Avatar
check out prothane
Old Mar 24, 2006 | 09:37 PM
sacicons's Avatar
If youre using inserts, you dont have to press anything. they just slide into the spaces in the stock bushing. I had to do a little trimming to fit my 00 Si bushings into my mounts, but nothing serious. They are a pretty easy install if you know how to remove and replace a mount.
Old Mar 25, 2006 | 12:18 AM
yeah i have the prothane ones and they just slid right into the old mount. The timing belt side one i had to completely cut out to put in the new prothane motor mount and i had to trim it to fit because my motor isnt v-tec...
BREmotorsports
Feb 9, 2006 05:09 PM
Dickie
EG Swaps
Jan 9, 2006 02:10 PM
twon
Oct 5, 2005 11:41 AM
fastest_ex
May 8, 2005 03:33 PM
grncivicvtec
EK Swaps
Feb 20, 2005 06:16 PM
