Motor tuning
Old May 23, 2005 | 08:23 PM
fast93civic's Avatar
Default Motor tuning
Is it possible to use a vacum meter tool to slightly tune the d16 motor? These tools I know are used on carburated engines to tune for best air fuel mixture and so on. Basically you want to be as close to 20 as possible on the meter. If possible, where do you stick the tool's vacum line on? Do you stick it on any vacum connection on the throttle body or the manifold? For the tuning part, this is similar to the carburator, just enrich or lean out the mixture by adjusting the fuel pressure regulator. If this tuning is possible can some one let me know.
Thanks in advance!
Old May 24, 2005 | 12:31 AM
97CivicEX's Avatar
Default RE: Motor tuning
To the best of my knowledge the fuel pressure regulator only "regulates" the fuel pressure pre injectors. What what makes the engine run richer or leaner is the duration of the injectors on position. If you want to tune an EFI engine the best way is with a wide band O2 sensor and a piggy back computer or programable ECU. Check out this site for great information and products. They have good how to tune videos:
http://www.innovatemotorsports.com/index.html
Old May 24, 2005 | 06:17 AM
thanks!
sleepin stock
Oct 4, 2007 06:43 PM
topdogmancivic92
Aug 28, 2006 09:12 PM
dalifts
ED-EF Swaps
Apr 16, 2005 01:11 PM
hypnotixcrx
Mar 1, 2005 10:10 AM
nwhite82
Dec 2, 2004 01:49 AM
