Need advice on mini me set up
Old Aug 3, 2009 | 10:30 PM
nweaver87's Avatar
Default Need advice on mini me set up
Hi, I have a 92 civic cx. It has the stock d15 non vtech. I have been looking into getting a d16z6 head to put on my d15 to create a mini me. I was hoping someone could share some insite on this idea. I know it's a cheap way to mod a Honda but it's about all I can work with until I can find myself a better job. If the d16z6 head will bolt up to the d15 how do I go about hooking up the vtech and what kind of work would I need to do with the computer? What all do I need to get to make this work? Also I've been told that the d15 block and interals will not hold up to the RPM's of a vtech. How much of a problem will that be down the road?
Old Aug 3, 2009 | 10:39 PM
dont listen to what you have heard you can do a mini swap its not that hard
just get a d16z6 head,im,dizzy,p28 ecu and the plugs from the d16z6 wire harness and some pins from the plugs that hook up to the ecu
here is the wire diagram you only need to do the 1st,3rd,5th dont worry about the other wiring
driverosp0
Nov 12, 2009 05:41 PM
justin07731
Sep 8, 2009 12:39 PM
TurboToyzz
Feb 16, 2007 12:46 AM
GSXF
Feb 23, 2005 09:45 PM
