need help fast!!!!
Well i have had my 88 honda civic for about 4 months now and today when i pulled into burgerking it started blowing white smoke. So i think that i have blown a head gasket or cracked my head. It is also getting hot then cooling off and my heater quit working. Then when i tried to start it again it would barely turn over. So now what should i do. The last thing i did to it was put on a header pipe. The moter is a d15b7 out of a 95 civic. i need the car to go to work in and it is running bad.
I have a couple of qestions about how to proceed. Should i just replace the head gasket or the whole head. If i should replace the head will a 1.5 vetec fit on my block with out any clearence problems. I can get the head and a computer for the 1.5 vtec. I beleave it is a d15z6 head. I would like to put on a d16y8 head an dcomputer but i dont have them. Can anyone help i need my car back fast. |
RE: need help fast!!!!
Sorry the 1.5 vetec is a d15z1 head
If you take off the head your gonna need new head bolts too. Some people put the old ones back on but I would't recommend it.
white smoke? Sounds like coolant. Check the radiator and all the hoses. There very well may be a leak somewhere.
blue is oil i cant remember black... if im wrong somebody correct me. |
Black is soot, rich A/F ratio.
white = coolant
blue= oil black = l(like AOD said) engine is running too rich and soot is being put out (common on alot of tuner cars) |
tell me about it I have nothing but black coming out of my exhaust until i get my piggy back installed.
I thought so.
I forgot to add, on older cars, the hoses naturally dry rot and crack. That so far is the most obvious problem. I hope that helps for you! |
check you coolent level when the car is hot.. if its still full then you might have problems else were, but if its low then you could have a cracked head/block/ or leaking head gasket
hm riceburner beat me to it...but yeah check your headgasket.
