need more out of Y8
I am tryin to make my 97 civic ex run mid to low 13's in the 1/4 mile.right now i think it is run mid to high 14's.
i have AEM V2 cold air intake,ebay header,ebay test pipe, SKUNK 2 cat back, i have built the bottom end and jumped the compression up to 11.6 to 1,and i have a 50 of nitrous,
i will be ordering my cam in the nexted few day. and now for my question, what eles can i do to make my car faster with staying N/Aand break into low 13's
thanx for all the help
Acam? I call bs unless you show pics of the build because you would have a cam with that build and you say your just now getting one. The stock cam wiould not allow that engine to run worth a crap
Your saying your running mid 14's with a D16y8? We just did a H22a swap into my buddies 95Ex and it only runs low 14's to high 13's and its still a barely used motor. Lets see some slips to prove this!
No in all reality I see low 14's from what he has listed but I dont see anyone going through with that much work and leaving the stock cam in it. The D15B I had has been put into a eg hatch and has a 92-95 si transmission, S2 manifold, 4-1 header, H22 throttle body, lightened stock flywheel, excedy stg 2 clutch and it pulls a fender on another buddies bold on, clutch/flywheel upgraded ls teg that run 15.2 at Bristol. So I'd say around a low 15.2 maybe a high 15.1 and n2o does wonders for them adding gobs of tq everywhere you spray it. Like I said I dont call bs on the numbers with what he has, it should actually be a tad better but I'd like to see pics of the build.
the H22 throttle body did it do much help b/c i have a h22a (jdm) sit in my back yard... well it is in my accord but will not run b/c of no fire
and i got the dyno on it, some of yall might have already seen it onmy other post, but it had113 to the wheel no spray, and 158 with spray, so i am think about putin the 75 shot on it
briceman124
Jan 4, 2012 07:50 AM
xxeddixx
Aug 24, 2006 05:06 PM
LEVIII
Feb 3, 2006 02:52 PM
