need some torque
Old Oct 15, 2004 | 08:18 AM
mxpunk409's Avatar
Default need some torque
i was wondering if anyone know how i can get some torque outta my automatic. i would like to drop a 5spd in it, but i dont have the time or money. my buddies tell me to get a turbo, but that cost more than a 5spd trans.
Old Dec 4, 2004 | 03:23 PM
Kappa22's Avatar
Default RE: need some torque
I don't know what you consider a lot of money, but I think you would do well to chuck a 5spd in there. You could get one imported for 200-250 no prob, and you could sell your auto to make up for most of it. Plus, an auto to 5spd conversion is really easy. Also, do a valve adjustment on your car; that will help a lot. A couple things about that: ONLY DO IT WHEN THE CAR IS COLD, and make sure you have a good manual and a good gapper so you don't really deuce things up. Good luck in your torque quest.
Old Dec 4, 2004 | 07:06 PM
andryuha's Avatar
$200-250 for a manual conversion? Damn, now I'm wondering wether I should do it on my older corolla. Have you done it before? If so, is it a direct bolt-on, and is it hard to put in a clutch pedal? I saw the same kind of car that I have in the junkyard earlier this week with a 5spd. What part will I need besides the obvious ones?
Old Dec 4, 2004 | 07:11 PM
andryuha's Avatar
MXPUNK409:
If you are serious about tuning, you should definately convert to a 5spd, because the auto will never be as fast, and you will f*** it up pretty fast with a turbo.
Old Dec 4, 2004 | 09:08 PM
ohbiskits's Avatar
i have an auto tranny in my 91 hatch..soon to have a manual converion...i plan on pickin up the stuff if not a full donor car for the conversion...you need more then just the tranny but yea if you know a little its not bad..id much rather find a cheap donor car so i know definatly where everything goes but we will see...that is my next job after i put the vtec head and y8 intake manifold on...
Old Dec 5, 2004 | 10:31 AM
andryuha's Avatar
Do you know, which parts are needed specifically? From my understanding, I will need a tranny, shifter assembly, clutch and a brake pedal, master and slave cylinders, shifter linkage, and hard lines. Anything else?
Old Dec 5, 2004 | 01:23 PM
ohbiskits's Avatar
not positive on everything but that sounds about right...i will find out for you..unless someone on here beats me to it...
Old Dec 5, 2004 | 02:57 PM
andryuha's Avatar
dude, you're awesome, but after some searching on the internet, I am leaning more toward swapping a Silvertop 4age into my corolla. I might even go further and get a 4GZE, if I could find one (a supercharged version of 4age)
Old Dec 5, 2004 | 06:34 PM
sacicons's Avatar
mmm, 4 age.
Old Dec 6, 2004 | 12:08 AM
mpilic's Avatar
How much would a good manual conversion cost me, and could i do this conversion myself or is it safest to just get it done somewhere else.
