New Engine
Me and a buddy plan on dooing an engine swap on his civic cause the engine is starting to go and its got over 250k on it. We are looking at stock engines Oh yeah its a 94 civic ex. But wundering if there is anything else that will match up to the same mounts and reusing the ecu if possible. We have 800$ at our disposal. We were looking at zc's just cause they are cheap and easie to work on. He also has an auto so we are probably just wanting to get a complete block with transmission attached. We have been watching ebay for a while but the only problem we have is that we dont know which engines will be interchangeable with his without a lot of effort. I think its a sohc vtec.
RE: New Engine
best bet is to just get the same engine he's got if it's the SOHC vtec which i'm sure it is since it's an EX model.
-B |
RE: New Engine
yup or just get a d15b motor and put a y8 and all this crap blah blah just get the same motor lol and work on it. :D
RE: New Engine
stick with the z6 or a newer y8 and transfer all the accesories from the original except the intake manifold. the y8 is a little easier to build on.
RE: New Engine
does anyone know of any usefull websites to get these engines from
RE: New Engine
RE: New Engine
from what ive heard, those d15bs are a waste. its hard to get them running right. they have a three stage vtec and i never could find an ecu for it. plus, theyre from cars with a CVT, trans, so i doubt you could get the d15b ecu to work right anyway.
RE: New Engine
wel you dont have to get the d15b ecu you can get an ecu from another d-series motor and if you dont wanna get the d15b motor just get the si model the d16a6 and do the same thing to it. it has more compression and its a 1.6 instead of a 1.5.
RE: New Engine
and its a 1.6 instead of a 1.5 I hate to break it to you like this, but the D15's from 4G's actually have HIGHER CR's than the Si D16 engine (A6). |
RE: New Engine
well yes and no it really depends the condition of the motor i mean if you get a used one yeh the compression of lower but if you rebuilt it i bet it can have the same as the d15b.
