Nitrous and Turbo
Old May 22, 2006 | 11:44 PM
thedougler's Avatar
Default Nitrous and Turbo
If you have a turbo kit already installed is it ok to put on a nitrous system also?
Old May 23, 2006 | 02:54 AM
99civic_boosted's Avatar
Default RE: Nitrous and Turbo
The only way I would recommend using the two together is with a "Pressure Deactivation Switch". The nitrous system disengages once the turbo has achieved a set boost level. This would eliminate the lag of the turbo and prevent you from killing you engine. I believe Edelbrock sell the switch.
Old May 23, 2006 | 08:19 AM
^exactly.
......and I highly recommend you buy some slicks and new motor mounts, or else you'll be wheel hopping down the 1320
Old May 23, 2006 | 10:06 AM
riceburner700's Avatar
wheelhop sucks
Old May 23, 2006 | 11:32 AM
thedougler's Avatar
New motor mounts help with wheel hop...I always thought it was the suspension!
Old May 23, 2006 | 01:06 PM
Nail I3unny's Avatar
motor mounts do have a lot to do with wheel hop. in stock mounts, the engine can move and bounce around ever so slightly in th emounts. this causes movement in the chassis and results in wheel hop. aftermarket motor mounts are much more rigid and wont let the engine move like that...reducing and often removing wheel hop.
Old May 24, 2006 | 01:21 AM
ORIGINAL: thedougler
Solved mine.
But as Nail I3unny stated "aftermarket motor mounts" but they also cause the car to viberate a little more since there is less give.
Old May 24, 2006 | 12:51 PM
larsenracing's Avatar
Suspension can have alot to do with it to and the mounts help alot to. I would go with out the nitrous unless you are having lag problems. Also it you use nitrous with the turbo you will loose traction very easy with out slicks. Sence you are FWD some lag helps like on my GS-T if i had no lag there would be no way to get the power to the ground i have lots of problems on the track already and once i hit full boost on the streeti cant get any tractinon there and i run expensave tires on it.
http://www.tirerack.com/tires/tires....e1=yes&place=3
Old May 24, 2006 | 01:22 PM
motor mount inserts do vibrate everything inside the car and outside a tad bt more
Old May 24, 2006 | 02:22 PM
neon3kgt's Avatar
its really only noticeable at idle... after that it doesnt seem any diffrent.
