No Heat..
Old Mar 3, 2005 | 07:09 AM
AnakinKenobe's Avatar
Default No Heat..
I dont have any heat.... whats up with that, its just cold air that blows...
Old Mar 3, 2005 | 09:28 AM
imadj's Avatar
Default RE: No Heat..
What year is it? My 94 HB had the same prob when I slammed the heater to hot. A gromet behind heater came loose the cable did not adjust the temp correctly. easy fix: you can try to get at through the glove box by holding the wire casing in place(usually black) and adjusting the control or to see it you will have to pull the radio..Works on my 94 hope this helps.
Old Mar 3, 2005 | 09:13 PM
ahhhhh
vdog
Sep 29, 2006 11:35 PM
Forty04
May 11, 2005 09:11 AM
malmsteen
Mar 15, 2005 03:47 PM
Devil
Jan 31, 2005 03:16 PM
mytsurfer
Dec 9, 2004 07:35 AM
