Oil leak from the Dizzy ...
Old May 5, 2005 | 01:05 PM
AnakinKenobe's Avatar
Default Oil leak from the Dizzy ...
Just as it says, i have an oil leak due to my distributor i have made little gaskets to go inbetween the dizzy and the head but as soon as i go for a test drive there the oil leak is.... this is my second dizzy could it be a slight warping on the part of the head the dizzy mounts to??? any ideas for a solution????
Old May 5, 2005 | 07:22 PM
AOL.COM's Avatar
Default RE: Oil leak from the Dizzy ...
wow dude --still givin u problems---as a last resort i would try this---pop out distributor & clean off bottom of dist. & hole in the head ---then get a big tube of black rtv gasket glue --apply a 1" x1" glob of glue over "dizzy" ring --then jam it back in [dont move it ] go have a couple of beers [sm=icon_cheers.gif] let it dry overnite --fire it up in the morning ---if it still leaks ? its comming from someplace else[sm=headbang.gif]
Old May 5, 2005 | 09:39 PM
Pete's Avatar
ya check any other O rings u might see there too......that SHOULD work but murpheys law says otherwise.
Old May 6, 2005 | 09:32 AM
yea its a new o-ring in there
theRDRman
Nov 28, 2011 04:18 PM
shadow_93
Dec 28, 2009 11:26 AM
oilltd
Jun 10, 2008 04:06 PM
mokijo2
Dec 27, 2007 12:11 AM
