oil pan
just let the oil drain out for like an hour so you get as much out of it as posible so you have less of a mess.... you will have to probably have to remove the flywheel bottom cover to get to the 2 nuts behind it in order to remove the oil pan.... Get a new gasket or else you will be sry, also right were the oil pan dips down on the oposite sides of each other put some liquid gasket right on the bends were they start to turn downwards or else that is were the oil pan is gonna leak first... and then reinstall the oil pan and tighten everything evenly and snuggly and you should be golden..
Execut1ve
Feb 6, 2012 07:29 AM
cvcrcr99
Nov 16, 2011 01:55 PM
ic892003
20
Aug 21, 2008 03:40 PM
oilltd
Jun 10, 2008 04:06 PM
oilltd
South West
Jun 10, 2008 03:07 PM
