Oil pan for a D16y8
Old May 21, 2009 | 06:31 PM
evan19's Avatar
Default Oil pan for a D16y8
Hi i am new to this forum and i have a question that has brought me a day of hell.
I ordered this oil pan from autozone and...
http://www.autozone.com/autozone/cat...061&questions=[]
i went to install it with my brother and it doesnt have two mounts that connect to the transmission like the OEM one does. Soooo what do i do? oh and also the gasket for the oil pan that came with it seems very odd looking, like its a cicle shape that isnt flat, and alsmost seems like a universal gasket. whats up with that also??
feed back is much appreciated cuz im leakin oil as we speak!!
thanks
Old May 21, 2009 | 09:02 PM
please explain better the circle shaped gasket.
the engine stiffeners (those mounts you are referring to) aren't part of the oil pan, they are separate. simply reuse your original ones.
Old May 21, 2009 | 09:37 PM
evan19's Avatar
no it connects up to the trannsmission. its a manual. there are little flanges that have a bolt on each side(2 sides) that connect to the transmission and the one i bought doesnt have that.
Old May 21, 2009 | 09:41 PM
I know what they are, I just changed my oil pan gasket 2 weeks ago. They bolt to the bottom of the engine though, not the oil pan.
Or are you talking about the flywheel access plate?
Old May 22, 2009 | 10:39 AM
evan19's Avatar
no it looked like it bolted directly to the oil pan.
Old May 22, 2009 | 11:55 AM
a picture speaks a thousand words
Old May 23, 2009 | 08:39 AM
evan19's Avatar
i will have some up after im off work today.
Old May 23, 2009 | 03:24 PM
gsumano's Avatar
There are two little mounts that are bolted to the oil pan and the transmission, only the d16y8 have them.
Anyways, don't worry about them, you don't really need them.. .. I didn't installed them when I replaced my aluminum d16y8 oil pan for the d16y7 steel oil pan (which does not have the holes for the mounts).
Old May 23, 2009 | 04:05 PM
The D16Z6 has them too, I guess they're different though. Mine are bolted to the block and not the oil pan. Same though on the transmission.
Old May 23, 2009 | 08:39 PM
rcherr642z's Avatar
i did the exact same thing a few months ago on my previous civic... i returned the autozone crapper and looked at the one from orieley (or however you spell that) and it too was crap...
i ended up buying the one from an online honda dealer (believe it was majestic honda) which was WAY cheaper than local dealership... it was still $$$.. i think about $200...
but yeah, the crapper ones from the auto stores are lacking the two attachment points.
oilltd
Jun 10, 2008 04:06 PM
97_ex
Apr 15, 2007 12:31 AM
ivtec
Jul 4, 2006 02:15 AM
mxs
Jun 28, 2006 02:17 PM
